Log non translated texts
Is there any way to log non translated texts in EPiServer?
/Jonas
#57375
Mar 13, 2012 8:13
Looking at the Translate methods in EPiServer.Core.LanguageManager, you can see that the "[Missing text ...]" string is hardcoded as a return value if a text hasn't been translated:
public string Translate(string key, string language)
    string str = this.TranslateRaw(key, language);
    if (str == null)
        return ("[Missing text " + key + " for " + language + "]");
    return str;
So what you could do is create your own Translate method that calls LanguageManager.Instance.Translate (and the overload methods if you're using those), and checks if the return value contains "[Missing text...]". If so, log the non translated text:
public static class MyLanguageManager
        public static string Translate(string key)
            string translatedText = LanguageManager.Instance.Translate(key);
            if (!string.IsNullOrEmpty(translatedText) && translatedText.StartsWith("[Missing text ")) // Or you can use Regex
                Logger.Debug(translatedText);
            return translatedText;
Now, instead of calling LanguageManager.Instance.Translate(...) or BasePage.Translate(...) elsewhere in your code, you call MyLanguageManager.Translate(...) instead.
I hope this helps!
Karoline
#57771
Mar 27, 2012 12:39
