File Listing Sample Template
What happened with File Listing Sample Template from CMS 5? Anything in CMS 6 R2 templates that is suppesed to replace that sample template?
#57842
Mar 30, 2012 10:17
Hi Henate,
I would recommend the built in property Link Collection for that purpose. It can hold any types of links, even files (in the VPP).
#57847
Mar 30, 2012 12:37
IMHO you should never use anything straight off the sample templates...
There is a FileDataSource but it usually disappoints me.
I prefer to collect the files and directories and files my self. Something like this:
private void GetDirectories(UnifiedDirectory directory)
foreach (UnifiedDirectory subDirectory in directory.Directories)
if (subDirectory.QueryDistinctAccess(AccessLevel.Read)) { ...
#57871
Edited, Apr 01, 2012 23:06
Hi Henate
The File Listing sample code is still in the Alloy Tech Sample site. Take a look under /templates/AlloyTech/Units/Placeable/FileList.ascx. When it comes to Johan's comment above about using code from the sample templates I disagree, I use alot of the code from the sample site, but I make sure to understand everything I pull from it before adding it to my projects (as we should with anything we add, always understand everything our code does).
Hope this helps.
Frederik
#57933
Apr 03, 2012 19:12
#57941
Apr 04, 2012 12:11
