Check which .NET Framework version Deployment Center is running on and try changing it between 2.0 and 4.0.
Also try changing the app pool to 32-bit mode and see if the 5 R2 site is still running. Deployment Center runs in 32-bit mode and this will be sort of like a pre check that it will be able to "run" the site internally.
Can the environment successfully run both 5 R2 and 6 R1 (other) sites?
When i try to upgrade version 5 R2 to version 6.0 i have this error.
An unhandled error has occured:
Cannot resolve dependencies for the following module(s)
EPiServer.Web.InitializationModule
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.0.530.0\Upgrade\System Scripts\Upgrad
e Site (SqlServer).ps1:489 char:26
+ Upgrade-EPiDdsIdentities <<<< $wizard.SelectedApplication
Get-EPiIsBulkInstalling
An error has occured and the transaction will be rolled back
Rolledback
At C:\Program Files (x86)\EPiServer\CMS\6.0.530.0\Upgrade\System Scripts\Upgrade Site (SqlServer).ps1:489 char:26
System.InvalidOperationException: Cannot resolve dependencies for the following module(s)
at EPiServer.Framework.Initialization.InitializationEngine.CreateDependencySortedModules(IEnumerable`1 modules)
at EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.StaticInitialization(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType)
at EPiServer.Install.CMS.Common.EPiServerCMSWrapper.InitalizeEPiServer(String webConfigPath)
at EPiServer.Install.CMS.Common.EPiServerCMSWrapper.Initialize(String destinationPath, String virtualDirectory)
at EPiServer.Upgrade.CMS5.UpgradeDdsIdentitiesCmdlet.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
Can anybody help me.
Thank you.
