I assume you are using the SQL Server Role and Membership providers for authentication / authorization. Sounds like something has been changed in the Membership tables of your db.
Hi:
After an upgrade to SQL Server 2008 we cannot login to the Edit/Admin mode of our EPiServer CMS installation. We found a temporary work around to get into Edit Mode directly without login in but of course we would like to use the normal way, promting the user to login as usual. Is there any known issues/bugs or changes I need to make to make it work with 2008.
The connection to the DB works since after the work around we are able to add/edit/delete content and work as normal in both Edit/Admin Mode.
