What happens if you try to printe the property directly into the markup?
E.g.
<%= CurrentPage ["prpDefault2"] %>
Or this in the code behind:
PropertyData property = CurrentPage.Property["prpDefault2"];
if (property != null && !property.IsNull)
DoSomething();
Be aware property names are case sensitive.
For test the operation with the Properties we use an existing default project MyEPiServerSite.
No new parameters and settings were not used, but the connection string to the database connectionStrings.config
Step 1
Check what properties exist and are available in the Default.aspx
(added a TextBox and it print all of the existing Property values)
protected void Button2_Click(object sender, EventArgs e)
TextBox2.Text = "";
for (int i = 1; i < CurrentPage.Property.Count; i++)
try
TextBox2.Text = TextBox2.Text + i.ToString() + " [" + CurrentPage.Property[i].Name + "] " + CurrentPage.Property[i].Value.ToString() + Environment.NewLine;
catch (Exception ex)
TextBox2.Text = TextBox2.Text + i.ToString() + " [" + CurrentPage.Property[i].Name + "] " + ex.Message + Environment.NewLine;
Step 2
Added to the project a new form Default2.aspx
Registered it in Admin Mode as a new Page Type
Add a new property "prpDefault2" to form (Page Type) Default2.aspx
Step 3
On a new form Default2.aspx added a TextBox and print all of the existing Property values
(See above code)
Result:
On a new form Default2.aspx printed the same values as for Default.aspx
Property "prpDefault2" not found.
Questions:
1. What have we done wrong?
2. Why the new property ("prpDefault2") is not available on a new form Default2.aspx
