I have few user that have problem to access to the Intranet. All users are inte the same domain and groups so I cant figured out whats the problem is.
Anyone that have a clue?
Some or all identity references could not be translated.
Exception Details: System.Security.Principal.IdentityNotMappedException: Some or all identity references could not be translated.
Source Error:
Stack Trace:
[IdentityNotMappedException: Some or all identity references could not be translated.]
System.Security.Principal.SecurityIdentifier.Translate(IdentityReferenceCollection sourceSids, Type targetType, Boolean forceSuccess) +7608576
System.Security.Principal.SecurityIdentifier.Translate(Type targetType) +100
EPiServer.Security.WindowsMembershipProvider.GroupNamesFromIdentity(WindowsIdentity identity, String[] deletePrefix) +259
EPiServer.Security.WindowsRoleProvider.GetRolesForUser(String username) +110
EPiServer.Security.MultiplexingRoleProvider.GetRolesForUser(String username) +35
System.Web.Security.RolePrincipal.IsInRole(String role) +164
EPiServer.Security.VirtualRolePrincipal.IsInRole(String role) +101
System.Web.Configuration.AuthorizationRule.IsTheUserInAnyRole(StringCollection roles, IPrincipal principal) +123
System.Web.Configuration.AuthorizationRule.IsUserAllowed(IPrincipal user, String verb) +256
System.Web.Configuration.AuthorizationRuleCollection.IsUserAllowed(IPrincipal user, String verb) +199
System.Web.Security.UrlAuthorizationModule.OnEnter(Object source, EventArgs eventArgs) +8778492
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
#49497
Mar 21, 2011 14:32
Are you using a AD for the users?
#49498
Mar 21, 2011 15:13
Yes, we are using AD and we got problem after we migrated (change domain). We hava more than 500 users and I still can't understand why just few of them got the error. Especially when all the user are in the same domain and groups.
Petter - Do you have a clue?
#49682
Mar 28, 2011 20:08
Hmm. Was thinking it could be the blank space or invalid char issue in the AD provider first but after a second glance I see that the stack trace doesn't match.
I would try and isolate what users that get the error and then try and find out what is unique with them.
Perhaps they are all part of a group that isn't synced into the server and then System.Security.Principal.SecurityIdentifier.Translate can't find it. (just guessing here)
#49713
Mar 29, 2011 15:35
Hi there
We're facing the same problem here. Did anyone found a solution?
Thanks and Best Regards
Xuan
#56312
Jan 17, 2012 14:49
was it a case sensitivity issue?
#58324
Apr 19, 2012 12:46
Did u find any resolution to it?
Br
Henke
#77236
Nov 13, 2013 14:19
