EPiServer out of the box properties
When you create a Page of PageType, EPiServer gives you some out of the box properties, e.g. 'Page name in web address', and some other ones (usually placed in the 'Advanced Information' tab). Is there a way I can move those properties to a different tab, a tab that I have created myself, a custom tab? Is this possible?
If this isn't available in CMS 5 R2, is this a feature that is included in CMS 6?
Edon
#46891
Jan 10, 2011 11:15
See the following blog post from Henrik Nyström that deals with this: http://thisisnothing.wordpress.com/2010/04/09/modify-the-built-in-episerver-properties/
/Linus
#46898
Jan 10, 2011 12:54
Thanks Linus, I saw that and got it on my website, but I am not sure how will this affect the performance of my site, or what are the cons of using that method. What should I look out for when adapting DLL's from external sources, is the dll on that site considered as an external plug-in to EPiServer?
Also on that note, is there a way I can change the type or the name of the buil-in properties? This sounds like a separate issue.
Edon
#47105
Jan 14, 2011 11:11
Name can be changes in the lang/ files
the type you can't change but you could use this
http://labs.episerver.com/en/Blogs/Anders-Hattestad/Dates/2009/2/PropertyDate-and-editores-in-different-TimeZone/
if its the date property you want to change
#47109
Jan 14, 2011 11:25
