File not found ...FileSummary.Config
Upgraded a CMS 5 R1 to R2 and moved it to Server 2008 and IIS 7.
When the editors tried to add a file, they got a file not found-error on FileSummary.config. I checked the site and it was´nt located in the root directory, instead I found it where the EPi-admin files are located. Moved it to the site root and then it worked.
My question: Should it be located in the site root or in the admin root? If the answer is admin root, how do I get it to work?
#46929
Jan 11, 2011 11:33
Check web.config and the virtualPath settings (look for the customFileSummary attribute). The default is your sites root folder.
Frederik
#46932
Jan 11, 2011 16:07
