Problems after upgrading to R2 SP2
We did an upgrade from R2 to R2 SP2 to solve a known problem, but then we got a new one, bigger! The two choices Edit and Create new in the page tree menu are not available to the user on every page. They are just gray and the user we tested with belongs to the editor and administrator groups so it should have suffient rights to perform the two actions.
Anyone had  the same problem or a solution to the problem?
/Mathias
#37567
Mar 11, 2010 12:03
I don't know how it could be related to the upgrade, and I don't know about the edit option, but create new will be disabled for a page even if the user has sufficient access rights if no languages are enabled for the subtree. It's a longshot, but check the language overview of the pages you can't publish under if any languages are enabled.
#37568
Mar 11, 2010 13:05
Have no fear, former support team member Greger is here!
This is most likely the "This-page-is-not-available-for-the-active-language-bug" (#26280).
I'll send you a hotfix, Marcus.
If any one else encounters this issue, head over to the support section and ask for the hotfix.
#37588
Mar 12, 2010 10:35
