Mirroring HTML, Invalid URI Eror
Hi, I've set up mirroring according to this guide but I keep getting this error:
The job failed: Exception has been thrown by the target of an invocation. [
Error executing Channel "Static HTML" Destination "Static HTML Destination". Invalid URI: A Dos path must be rooted, for example, 'c:\'.]
My problem is that I can't find any place where this value is set or how I can change it. The Mirroring service can create the folder structure and copy the resource files but no pages are created there.
Any solution to this is much appreciated.
Here is the destination setup
  • The target directory: c:\StaticHtmlSite
  • Relative root path: /
  • Default name for files: Default.htm
  • Use the following property for folder names: PageName
  •  Verify check sum for all pages every time: Checked
  • Do not include file name in links: Checked
  • Apply channel filter: Checked
#38164
Mar 31, 2010 13:14
