Error when copy/past a page in editmode pagetree
Hi.
I've seem to have stumbled on a pretty anoying problem.
When logged in as administrator in edit-mode, and trying to copy page in one node for then to paste it in another node I get a Server Error in the EditCommand IFrame (the one top left with all the buttons :) )
Error as followed:
Exception Details: System.Net.WebException: The request failed with HTTP status 404: Not Found.
Stack Trace:
[WebException: The request failed with HTTP status 404: Not Found.]
   System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +431201
   System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +204
   NetworkedPlanet.WebServiceClient.TMService.ProcessTransaction(String topicmap, XmlNode tmfragment) +65
   NetworkedPlanet.EPiServerModule.EPiTMServiceHelper.ProcessTransaction(TopicMapTransaction txn) +443
   NetworkedPlanet.EPiServerModule.EPiTMServiceHelper.CreateTopic(String subjectIdentifier, String name, String topicTypeSubjectIdentifier) +180
   NetworkedPlanet.EPiServerModule.EPiTMServiceHelper.EnsureTopic(String subjectIdentifier, String name, String topicTypeSubjectIdentifier) +315
   NetworkedPlanet.EPiServerModule.EPiConfig.get_NP_TM_PageIdOccurrenceTypeId() +48
   NetworkedPlanet.EPiServerModule.IdentityHelper.GetTopicIdsByPageIds(IEnumerable`1 pageIdList) +194
   NetworkedPlanet.EPiServerModule.PageHierarchyCopyUtility.CreateTopicHierarchyForCopiedPages(PageData sourcePage, PageData copiedPage, CopyPageEventArgs copyArgs) +46
   NetworkedPlanet.EPiServerModule.TopicMapEventHandler.EPDataFactory_CreatedPage(Object sender, PageEventArgs e) +370
   EPiServer.PageEventHandler.Invoke(Object sender, PageEventArgs e) +0
   EPiServer.Core.PageStoreBase.RaisePageEvent(Object key, PageEventArgs eventArgs) +76
   EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, AccessLevel requiredSourceAccess, AccessLevel requiredDestinationAccess, Boolean publishOnDestination, Boolean allowThreading) +368
   EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, Boolean allowThreading) +76
   EPiServer.UI.Edit.CommandActions.PasteCommandTool_Click(Object sender, EventArgs e) +715
   EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +107
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +135
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +175
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
#37499
Mar 09, 2010 8:28
