Method not found: 'Boolean EPiServer.Core.PageLanguageSettingsTree.IsLanguageAllowedForCreation(EPiServer.Core.PageReference, System.String)'.
MissingMethodException: Method not found: 'Boolean EPiServer.Core.PageLanguageSettingsTree.IsLanguageAllowedForCreation(EPiServer.Core.PageReference, System.String)'.]
EPiServer.UI.Edit.PageExplorer.PageTreeView_ItemDataBound(Object sender, PageTreeViewEventArgs e) +0
EPiServer.UI.WebControls.PageTreeView.CreateTemplatedControls(ITemplate template, PageTreeNode treeNode, Int32 position, Boolean dataBinding) +223
EPiServer.UI.WebControls.PageTreeView.CreateChildControlsFromItems(Boolean dataBinding) +155
EPiServer.UI.WebControls.PageTreeView.PerformDataBinding() +205
System.Web.UI.WebControls.HierarchicalDataBoundControl.PerformSelect() +114
EPiServer.UI.Edit.PageExplorer.OnLoad(EventArgs e) +623
System.Web.UI.Control.LoadRecursive() +66
System.Web.UI.Control.LoadRecursive() +191
Just popped up out of nowhere. The error occurs in EPiServer is trying to render the PageTree. Any ideas?
#37244
Feb 26, 2010 11:15
Hi Viktor,
What version? Any hotfix applied?
#37539
Mar 09, 2010 22:56
Seems to be working on other computers tho. In the GAC the version of EPiServer is: 5.2.375.
I've applied the hotfix for sites upgraded with to R2.
http://support.ep.se/upload/Hotfixes/EPiServer5R2SP2_Hotfix_upgraded%20sites.zip
#37621
Mar 15, 2010 10:44
