Standalone Image Editor
Has anyone successfully used the Image Editor standalone (e.g. to let users edit images directly from a page)? It's popped in it's own window so I can copy the location (which includes the image to edit in the querystring) and browse to it in a separate window, but then the image doesn't load (ajax "spiral" never finishes). Is there more magic to this popup than the URL?
#31684
Aug 07, 2009 9:10
Because the Image Editor depends on several dialog arguments, it's not as straight forward as opening the url in a new window.
You need to open the dialog using EPiServer script methods.These links should guide you in the right direction:
http://world.episerver.com/en/Articles/Items/Modal-Dialogs-in-the-EPiServer-UI-for-non-IE-Browsers/
https://www.coderesort.com/p/epicode/browser/Intergen.EP.MultiPageProperty/5.x/Intergen/Dialogs/MultipageSelector.aspx
#31760
Aug 11, 2009 12:29
