Quick save in EPiServer
I want to save the article/page that I'm currently working on without automatic switch to the "view" tab in EPiServer.
Eg, when I write the page content I want to press CTRL+S and the properties will be saved into the page without leaving the ongoing edit phase. I want to continue write my page in the actual property. Just like a quick save as in MS Word.
Is this possible to accomplish? Any ideas?
Regards, Andreas Ek, Flow Communication AB
#31216
Jul 09, 2009 14:06
I'm a bit confused. In EPiServer CMS 5, and very late version of CMS 4, there is a "Save" button that does what you want. Is it that you are running a pre 4.62 version?
As for the ctrl+s to trigger the function, that may be a bit trickier. To save the page there has to be a post back. So you would need to add some custom script that did the same as pushing the save button.
Regards
Per Gunsarfs
EPiServer CMS development team
#31219
Jul 09, 2009 16:58
But cannot this function be implemented in the standard edition of Episerver?
I mean it is standard short commands :)
Standard commands in many publishing systems too...
Wishlist item?
regards,
/bettina
#31220
Jul 09, 2009 17:09
Yes, I agree, short commands would be a very nice addition. Ctrl+s however may not be a perfect choice, since the browser/OS already uses that.
Definatly a wish list item, and something we keep in mind when developing new UI:s.
Regards
Per Gunsarfs
#31221
Jul 09, 2009 17:13
With CTRL+S the page would be saved and the page should not reload.
For example: I'm writing a long story and in the middle of the text I want to save. If I press the save button the page reloads and the view gets into "view" mode. I really just want to continue my writing. CTRL+S and no reload would do the trick. Just background saving.
#31229
Jul 10, 2009 11:28
CTRL+S could be overrided because the save html page is irrelevant in this case.
#31230
Jul 10, 2009 11:30
