Disable Format Paragraph drop down in Editor
Hi.
Is it posible to disable the Format Paragraph drop down list in the editor?  I have made a property that inherits from PropertyLongString. I have overriden the EditorToolOptions property and set it to return this:
public override EditorToolOption EditorToolOptions
get { return EditorToolOption.Undo | EditorToolOption.Redo | EditorToolOption.SpellCheck | EditorToolOption.Refresh | EditorToolOption.Find; }
set { base.EditorToolOptions = value; }
It works fine. I only get the EditorToolOptions that is specified, but I also get the Format Paragraph drop down. Why is this?!
I bellive that this line of code from PropertyLongStringControl is causing this:
protected virtual WebControl CreateHtmlEditor()
editor.ContentCssFile = this.GetCssPaths();
I could make a own propertycontrol class that inherits from PropertyLongStringControl and override GetCssPaths, but does it have to be that diffucult?!
Br, Tore
#31212
Jul 09, 2009 8:13
It seems the FormatParagraph tool isn't configurable. I can't see any reason why it shouldn't be configurable like the other tools so I've filed a bug report.
Unfortunately I can't provide any information that solves your problem in an easy way.
/Stefan
#31231
Jul 10, 2009 11:33
Hi Stefan.
Thanks for your answer.  I solved by overrideing the GetCssPaths method in the PropertyLongStringControl. I still get the "Remove formatting" option in the dropdown, but all the other options are removed
Here is the code if others have the same problem:
MyProperty.cs
[Serializable]
[PageDefinitionTypePlugIn]
public class MyProperty : PropertyLongString
public override IPropertyControl CreatePropertyControl()
return new MyPropertyControl();
MyPropertyControl.cs
public class MyPropertyControl : PropertyLongStringControl
protected override string GetCssPaths()
return string.Empty;
Br, Tore
#31233
Jul 10, 2009 13:05
