When used from the file manager it's opened with the following code
var imageEditorUrl = EPi.ResolveUrlFromUI("Edit/ImageEditor/ImageEditor.aspx");EPi.CreateDialog(imageEditorUrl + "?img=" + filePath + "&openedfromfilemanager=true", OnEditImageCompleted, null, {src: filePath}, {width: width, height: height});
where width and height are the dialog dimensions and filePath is the path to the image.
Has anyone tried using the ImageEditor dialog (UI/Edit/ImageEditor/ImageEditor.aspx) from code?
To be more specific: what javascript dialogArguments is necessary to use this dialog from outside the wysiwyg editor?
