Submit multiple xforms with one button / weave xforms into oneanother
we're trying to adapt the forms-generator capabilities of episerver to our clients needs that involve dynamically adding input fields to a form given certain criteria.
For example, in a web shop, you often have the option of specifying a different address for receiving the merchandise than the address for receiving teh invoice. Upon checking a checkbox entitled "click here to specify an alternative address for invocing", a set of new input fields would appear.
Any thoughts on doing this with xforms in episerver cms 5?
I've thought about splitting the form so that there is an address-form that may appear 1 or two times, and another form for the other info needed in the form.
How would I go about making sure that all the info from all the three different xforms being displayed on a page would be saved correctly?
Any thoughts on alternative solutions would be appreciated also!
 br
Jørgen
#29704
May 08, 2009 16:48
Dear Jorgen,
I am facing exactly the same issue with the codebase that I am working on at the moment with v5 R2.  I was thinking along the lines of a multicast delegate to fire all the save events in success, though of course this will not allow the saving of the form as a single instance. Perhaps this would involve some code to merge the XML elements that are completed and contained in the  <instance> tag?  But what about the raw dump at the bottom of the XForm?
Thank you in advance.
Regards,
#49361
Mar 14, 2011 18:34
