Thanks for the answer!
I installed EPiServer again and now everything works perfectly.
Best regards
/Niklas
Hi ,
When i try to access the page the following error is throwing 1.parameter has no pageset 2. parameter name:page Link. and the error is showing in PageBase.cs file.
Can any one pls figure out this issue? Thanks in advance.
Regards,
Murali Krishna.
Hello everyone!
I get the following error message when I am adding new pages or any other command in Edit mode, I have read a post stating that this was an issue that should have been solved in SP1, I am running version 5.2.375.133 on Windows vista SP1. Any help would be greatly appreciated, if any further information is needed please let me know.
Best regards
/Niklas Johansson
Exception Details: System.ArgumentNullException: Parameter has no page set
Parameter name: pageLink
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.Stack Trace:
[ArgumentNullException: Parameter has no page set
Parameter name: pageLink]
EPiServer.DataFactory.GetChildren(PageReference pageLink, ILanguageSelector selector, Int32 startIndex, Int32 maxRows) +335
EPiServer.DataFactory.GetChildren(PageReference pageLink, ILanguageSelector selector) +12
Dropit.Extension.Controllers.ContainerManager.GetShadowPage(PageReference containerPageLink, PageReference pageLink) +119
Dropit.Extension.Controllers.ContainerManager.GetSiteRootContainer(PageReference startPage) +125
Dropit.Extension.Controllers.ContainerManager.GetTemplateContainer(PageReference startPage) +118
Dropit.Extension.Controllers.TemplateManager.List() +60
Dropit.Extension.Controllers.TemplateManager.List(Boolean visibleInMenu) +40
Dropit.Extension.Controllers.TemplateManager.ListAllowedTemplates(PageReference pageLink) +91
Dropit.Extension.UI.Edit.ExtensionNewPage.OnLoad(EventArgs e) +176
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
