Find pages by URLSegment
I´ve done some testings, but with no success. Is it possible to search by URLSegment?
PropertyCriteria criteria = new PropertyCriteria();
criteria.Condition = EPiServer.Filters.CompareCondition.Equal;
criteria.Name = "URLSegment";
criteria.Type = PropertyDataType.String;
criteria.Value = "test";
PropertyCriteriaCollection criterias = new PropertyCriteriaCollection();
criterias.Add(criteria);
#29174
Apr 14, 2009 11:04
I've not tested it, but try using the following instead:
criteria.Name = "PageURLSegment"
All built in properties are prefixed with "Page".
Regards
Per Gunsarfs
EPiServer CMS Development team
#29177
Apr 14, 2009 11:42
Doesn´t work. But now it returns all pages instead so something happens.
criteria.Name = "PageURLSegment";
criteria.Required = true;
Is there another way to achieve this? I´m building a cross publishing plugin and a custom url rewriter.
So the page can have more than one url, e.g. example.com/archive/test/ (original url) and example.com/another-page/archive/test/ (custom url).
My problem is to convert the second url to an internal address. Now I´m truncating the second url to example.com/another-page/archive/ (the archive page exists on this url) and then try to find tha page "test" under example.com/archive/ and convert it to /templates/archive.aspx?id=1&articleId=2.
Today I´m using the method ConvertToInternal() to find the page using the orginal url to the archive where the page is published to and then add the url segment. But that doesn´t work if the we have another structure under  example.com/archive/ than a flat structure, e.g. example.com/archive/2008/01/test/.
#29181
Apr 14, 2009 13:42
Solved it by adding the same structure to both url's. E.g. exampel.com/archive/2008/01/test/ and exampel.com/another-page/archive/2008/01/test/.
#29187
Apr 14, 2009 16:01
