Please give some explanation of using CurrentPage property
I'm working with EPiServer Demo for a week or little more and very like it. But I have some problem with understanding some features. It would be great if anybody can give me an explanation.
I've made a simle website in two languages and included the QuickSearch control is delivered with the demo website. I created my own Search page for showing results.
My problem is: after submit the website is redirected to DEMO Search result page, but I would like to redirect it to my NEW Search result page (moreover in current language). I found some code in QuickSearch control:
PageReference searchPageRef = CurrentPage["SearchPage"] as PageReference;
if (searchPageRef != null)
PageData searchPage = GetPage(searchPageRef);
_searchPageUrl = searchPage.LinkURL;
The property CurrentPage["SearchPage"] returns DEMO Search result reference.
How can I set the property for example "MySearchPage" for getting my search page reference CurrentPage["MySearchPage"]?
Where in the admin tool is it possible to set that values for pages?
How the string id "SearchPage" is related to the DEMO Search page?
Under Site configuration section I found some settings:
Logotype
Contact page
Privacy page
Site map page
RSS Main Page
But there are no ways to add a new one.
Thank you
#29201
Apr 15, 2009 11:01
Hi Michael,
If you look at the comment for the SearchPageUrl you will see that is is by default set to take the PageReference pointed out by the dynamic property SearchPage.
If you are in editmode and on your startpage click the "edit dynamic properties" button. (its the one with three blocks in different colors) and there you will see that the property SearchPage will be pointing to the default searchpage. So it's just to change this to point to your searchpage instead.
Hope I made some sense.
#29203
Apr 15, 2009 11:42
CurrentPage[propname] gives you the underline value
CurrentPage.Property[propname] gives you the Property
#29204
Apr 15, 2009 12:06
Hi Petter,
Thank you for your answer very much. I've found that Dynamic properties buttonCool
#29205
Apr 15, 2009 13:00
