Language files not being recognised by Workflows
I have just upgraded a site from CMS5 R1 SP2 to R2 SP1.
I have implemented Workflows into the site and have got the workflows to send email upon assigning tasks.  This is a solution that we have used in 2 other projects on R2 SP1 and have worked fine.
The issue I am having, is that the email being sent out is full of [Missing text /personalization/task/status for en-GB] and is the same for all other fields.  I also get a similar message in the tasks list when it informs the user that they have a workflow task that needs attention.
I have checked the Language XML files and the translations are there (as default).
Is there something that I have missed or does anyone have any suggestions?
Carl
#29323
Apr 21, 2009 12:14
Did you find a solution for this issue as I am having the same problem.
Louise
#37224
Feb 25, 2010 14:16
i am also having this issue.  Is there any resolution?
Gwen
#41552
Jul 12, 2010 16:57
Hello,
I am having this problem aswell - keep getting emails like Carl mentioned.
We are using version 5 also.
Is there something that needs changing in the admin side, web.config etc?
Any pointers would be appreciated.
Cheers,
Henrik
#43107
Sep 14, 2010 11:24
hi,
we did manage to fix it but it was the third party supplier that fixed it and they didn't know how they did it.  I think making sure all of the correct reference files are in the bin is the first step and then making sure all of your language files exist.  I will have a think and try and see if there was anything else we did.
Gwen
#43108
Sep 14, 2010 11:47
#43109
Sep 14, 2010 11:48
Thanks for the info Gwen - didn't think to check the dlls. I'll be looking at this later this week - if I figure out why I'll submit the steps I took here.
#43110
Sep 14, 2010 11:51
Can anyone provide any clues as to how they resolved this? I'm having the same issue with workflow after switching to en-GB and with Relate+ as well.
Mark
#44309
Oct 08, 2010 10:00
In my case the issue was resolved by:
  1. Click on Root Folder
  2. My Settings tab
  3. Display Options tab
  4. Language Settings > Personal Language = Use System Language
Cheers,
Henrik
#44314
Oct 08, 2010 10:14
