Hide upload folder in file management
I'm stuck with this issue for weeks now. Please help.
Access rights works fine for upload folder. However, I'm trying to Hide the non relevant folders (requirement) from the user. They basically shouldn't be even able to view it.
Please help.
I tried this as well:
add the user folder to favorites and hide the upload folder(showinfilemanager="false")
but when I click on user folder under favorites: it throws runtime error.
Any help greatly appreciated
#29116
Apr 07, 2009 12:21
I get this error when I try to hide uplaod and access user folder from fav:
 The given key was not present in the dictionary.
Exception Details: System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
Source Error:
Stack Trace:
[KeyNotFoundException: The given key was not present in the dictionary.]
System.ThrowHelper.ThrowKeyNotFoundException() +28
System.Collections.Generic.Dictionary`2.get_Item(TKey key) +7452124
EPiServer.UI.Hosting.NavigationPath.BuildCookieCrumb() +443
EPiServer.UI.Hosting.NavigationPath.OnLoad(EventArgs e) +20
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Control.AddedControl(Control control, Int32 index) +265
System.Web.UI.ControlCollection.Add(Control child) +80
System.Web.UI.HtmlControls.HtmlTableRowControlCollection.Add(Control child) +43
System.Web.UI.ControlCollection.AddAt(Int32 index, Control child) +33
System.Web.UI.HtmlControls.HtmlTableRowControlCollection.AddAt(Int32 index, Control child) +48
System.Web.UI.HtmlControls.HtmlTableRowCollection.Insert(Int32 index, HtmlTableRow row) +32
System.Web.UI.HtmlControls.HtmlTableRowCollection.Add(HtmlTableRow row) +8
EPiServer.UI.Hosting.VirtualPathFileManager.LoadUserControl(String dialogName) +365
EPiServer.UI.Hosting.VirtualPathFileManager.CreateChildControls() +338
EPiServer.UI.Hosting.VirtualPathFileManager.DataBind() +50
EPiServer.UI.Hosting.VirtualPathFileManager.virtualPathControl_VirtualPathChanged(Object sender, VirtualPathChangedEventArgs args) +80
EPiServer.UI.Hosting.VirtualPathChangedEventHandler.Invoke(Object sender, VirtualPathChangedEventArgs e) +0
EPiServer.UI.Hosting.VirtualPathControl.RaiseVirtualPathChangedEvent(String virtualPath) +47
EPiServer.UI.Hosting.VirtualPathNavigator.RaiseVirtualPathChanged() +85
EPiServer.UI.Hosting.VirtualPathNavigator.HandleButtonControlClick(Object sender, EventArgs args) +212
System.Web.UI.WebControls.LinkButton.OnClick(EventArgs e) +111
System.Web.UI.WebControls.LinkButton.RaisePostBackEvent(String eventArgument) +79
System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +175
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint
#29117
Apr 07, 2009 12:28
