ConvertToExternal does not return friendly URL
After upgrading to R2-SP1, the following code doesnot return the friendly url. This issue is observed only in some enviroments [machine] and some other machine the call does return the expected friendly url.Are we missing any configuration in those enviroment.
EPiServer.Global.UrlRewriteProvider.ConvertToExternal(finalUrlBuilder, pageLink, System.Text.UTF8Encoding.UTF8);
#29518
Apr 30, 2009 12:06
This maybe a stupid question, but is friendly url turned on on those sites? If it's not ConvertToExternal will obviously not return a furl:ed url. If you want to make sure you can check what defaultProvider for urlRewrite is set to in web.config:
<urlRewrite defaultProvider="EPiServerFriendlyUrlRewriteProvider">
Regards
Per Gunsarfs
EPiServer CMS development team
#29519
Apr 30, 2009 16:12
Yes we have turned on the friendly url on the sites. Following is the snippet from the web.config.
 <providers>
   <add description="EPiServer standard Friendly URL rewriter" name="EPiServerFriendlyUrlRewriteProvider" type="EPiServer.Web.FriendlyUrlRewriteProvider,EPiServer" />
        <add description="EPiServer identity URL rewriter" name="EPiServerIdentityUrlRewriteProvider" type="EPiServer.Web.IdentityUrlRewriteProvider,EPiServer" />
        <add description="EPiServer bypass URL rewriter" name="EPiServerNullUrlRewriteProvider" type="EPiServer.Web.NullUrlRewriteProvider,EPiServer" />
      </providers>
</urlRewrite>
#29531
May 04, 2009 4:39
In R2 we have change UrlRewriteProvider from a field to a property. Make sure that you have recompiled your modules with latest CMS R2-sp1 binary.
Could that be the issue?
Regards,
Shahid
EPiServer Support Team.
#29667
May 08, 2009 8:46
