Migration tool Roles error
When trying to migrate a site I get the following error. I have queried tblSID and at least there are no duplicates in user/role names. What could be the problem?
[2009-03-05 13:54:58][Information] Migrating Roles...
[2009-03-05 13:54:58][Error] Migration terminated with error:
[2009-03-05 13:54:58][Error] System.Data.SqlClient.SqlException: Violation of PRIMARY KEY constraint 'PK__#76EBA2E9__77DFC722'. Cannot insert duplicate key in object 'dbo.@tbUsers'.
Cannot insert duplicate key row in object 'dbo.aspnet_Users' with unique index 'aspnet_Users_Index'.
The statement has been terminated.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at System.Web.Security.SqlRoleProvider.AddUsersToRolesCore(SqlConnection conn, String usernames, String roleNames)
at System.Web.Security.SqlRoleProvider.AddUsersToRoles(String[] usernames, String[] roleNames)
at System.Web.Security.Roles.AddUsersToRole(String[] usernames, String roleName)
at EPiServer.Migration.UserAndGroupHandler.CreateRole(MigrateRoleEventArgs roleArg)
at EPiServer.Migration.UserAndGroupHandler.MigrateRoles()
at EPiServer.Migration.MigrationWorkflow.MigrateRoles(Object sender, EventArgs e)
#28370
Mar 05, 2009 14:03
It turns out there was actually two duplicate users. One had a domain prefix which was dropped by the migration tool (selectable) but the other one was more subtile because it differed in the case of one letter, which then caused a conflict because the provider model uses case-insensitive usernames.
#28420
Mar 06, 2009 10:19
I ran into a new issue with profile properties: http://world.episerver.com/Forum/Pages/Thread.aspx?id=28421
#28422
Mar 06, 2009 10:25
