Error Executing Websites created from Episerver CMS 5
Hello,
I had installed Episerver CMS Ver 5.1.422.256.
Now if I create the empty Episerver website from Visual Studio 2005 then everything is working fine.
But when I am creating new Website with the help of Manager then I am facing error as
The trust relationship between the primary domain and the trusted domain failed.
Exception Details: System.SystemException: The trust relationship between the primary domain and the trusted domain failed.
Source Error:
Stack Trace:
[SystemException: The trust relationship between the primary domain and the trusted domain failed.
   System.Security.Principal.NTAccount.TranslateToSids(IdentityReferenceCollection sourceAccounts, Boolean& someFailed) +1167
   System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean& someFailed) +42
   System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean forceSuccess) +46
   System.Security.Principal.WindowsPrincipal.IsInRole(String role) +205
   EPiServer.Web.Hosting.VirtualPathUnifiedProvider.HasFileSystemRights(AuthorizationRuleCollection ruleCollection, FileSystemRights rightsDemand) +145
   EPiServer.Web.Hosting.VirtualPathUnifiedProvider.GetAndValidatePhysicalPathBase(String physicalPath) +209
   EPiServer.Web.Hosting.Versioning.VersioningFileSystem.Init(NameValueCollection config) +107
   EPiServer.Web.Hosting.VirtualPathVersioningProvider..ctor(String name, NameValueCollection configParameters) +198
   System.RuntimeMethodHandle._InvokeConstructor(Object[] args, SignatureStruct& signature, IntPtr declaringType) +0
   System.RuntimeMethodHandle.InvokeConstructor(Object[] args, SignatureStruct signature, RuntimeTypeHandle declaringType) +13
   System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +366
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +1036
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +114
   EPiServer.Web.Hosting.VirtualPathHandler.CreateVirtualPathProviderInstance(ProviderSettings providerSettings) +290
   EPiServer.Web.Hosting.VirtualPathHandler.InitializeProviders(ProviderSettingsCollection providers) +178
   EPiServer.Global.InitializeVirtualPathProviders() +117
   EPiServer.Global.StaticInitialization() +62
   EPiServer.Global.Global_BeginRequest(Object sender, EventArgs e) +119
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +92
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
#28475
Mar 10, 2009 12:58
Hello,
Also I changed the settings as shown in the link below but then also its not working.
 http://world.episerver.com/en/FAQ/Items/The-trust-relationship-between-the-primary-domain-and-the-trusted-domain-failed/
#28476
Mar 10, 2009 13:02
