Demo site, Problem with login into Edit mode
I have installed demo site for (EPiServer CMS 5.2.375.7) on win2003. I can login to the site but when try to use edit/admin mode I sends back to login page and I can't login again as same user (my administrator login on the server). I don't know how to fix this problem. Any help on this?
#28639
Mar 17, 2009 10:34
Perhaps the user you are logging in as is not a member of the groups with access to the UI location in web.config (check location/authorization tags for your UI paths). You speak about the demo site and I think the default after installation is that the windows membership/role provider is used, and the locations are configured for Administrators, WebAdmins and WebEditors. So you have to be a member of the windows Administrators group to log in to edit/admin mode.
#28642
Mar 17, 2009 11:09
What is your OS language?
#28653
Mar 17, 2009 14:40
I use the Administrator user when login. My OS language is Swedish.
#28698
Mar 18, 2009 15:33
Thanks, I put the tag bellow because the OS Language is Swedish and it works now.
<allow roles="WebEditors, WebAdmins, Administrators, Administratörer"/>
#28699
Mar 18, 2009 15:47
I have the same problem on Vista. My Os language is Russian. The code below doesn't work:
<allow roles="WebEditors, WebAdmins, Administrators, Администраторы"/>
Any ideas?
#28914
Mar 26, 2009 16:16
