Hi Cassandra,
Could you check that your user isn't added or a member of any group added to the "All functions available in the Editor". You find it in admin mode -> Config tab -> Permissions for Functions
Additionally you may need to remember that sometimes pages are cached. Updates to the aspx page will not be carried through until IIS is reset. I've had this problem in the past although it was version 4.6 that I was using.
Hi there,
In the admin > Page Types > when I use a XHTML string or Long string property. And try turning off (unticking) properties of the editor, it does not work (the unticking not the editor - the editor works fine).
So if i untick 'Bold' for example, it still shows up on the page in the editor and can still be used.
Anyone have the same problem or any solutions to try?
Cassandra
