Custom URL rewriting using httpModule in IIS7
Because EPiServer CMS 5 R2 SP2 does not handle incoming URLs that are not FURLs I have created a small httpmodule which rewrites the URL to a FURL to circumvent the problem. I put this in httpModules on IIS6 and it works like a charm. On IIS7 however, it causes static files, or at least stylesheets, to be delivered corrupt to the client. In the IIS7 web.config I have added the module both in <httpModules> and in <system.webServer><modules>
Can't I use this approach with IIS7 or did I miss something in the configuration?
#34564
Nov 09, 2009 16:32
