Table - Cell Alignment
i have a celltable with an image.
I wanto to change the alignment of the cell.
In the text editor:
right click -> cell properties -> align right.
It's work.
But when i save and publish the alignment doesn't work. (image to left).
The generated html seems correct:
<TABLE border=0 width="100%">
<TBODY>
<TR vAlign=top>
<TD align=right><IMG style="WIDTH: 111px; HEIGHT: 110px"  src="xxx"></TD>
Suggestions?
#34083
Oct 28, 2009 11:32
Anything blocking it to the right? We would need to see the rest of your code (both html and css), to be able to help.
#34109
Oct 28, 2009 18:00
<TABLE border=0 width="100%" height=158>
  <TBODY>
    <TR vAlign=top>
      <TD><P align=center>Test1</P></TD>
      <TD align=right><P align=right><IMG alt="" src="/Documents/Environment/M%c3%a4rkning/EUeko.png"></P></TD></TR>
    <TR vAlign=top>
      <TD><P align=center>Test2</P></TD>
      <TD>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</TD></TR></TBODY></TABLE>
#34422
Nov 06, 2009 15:03
The image gets displayed to the left of Test1? Sounds like the image has the float property set to left. To check this use a tool like Firebug to inspect the image.
#34423
Nov 06, 2009 15:07
#34424
Nov 06, 2009 15:07
Need to see the CSS for site (view mode), since it looked okay in the editor?
#34427
Nov 06, 2009 15:13
It was the CSS file :-)
p img {float:left;margin:1.5em 1.5em 1.5em 0;padding:0;}
#34428
Nov 06, 2009 15:28
Ah there you go, glad you found out of it :).
#34429
Nov 06, 2009 15:30
