SQL Server security configuration - mandatory roles for CMS 5 R2
Hi there,
Is there any public information from EPiServer on which roles that are mandatory for the sql server login when running CMS 5 R2. By default the login will be in role db_owner but I guess that's not really necessary, especially when admin and edit will be removed from the webserver.
Advice appreciated,
Regards
Jens
#34117
Oct 29, 2009 9:53
