Workflow email notification
I have a customer that will implement workflows but are a bit unhappy with the notification emails. Is there a possibility to change the text in the notification emails? without rewriting the basic workflows from scratch?
#33551
Oct 15, 2009 15:22
You can change parts of the message by editing the xml in workflowFoundation_EN.xml (for english).
The code EPiServer uses to print the approvalworkflow looks like this:
activity.Subject = string.Format(Translate(profile2.UserName, "/workflows/approval/approvedevent/pageapproved"), page.PageName);
activity.Body = string.Format(Translate(profile2.UserName, "/workflows/approval/approvedevent/approvedby"), profile.DisplayName);
activity.Body = activity.Body + "\n";
activity.Body = activity.Body + Translate(profile2.UserName, "/workflows/approval/approvedevent/comment") + ":\n";
 Hope that helps you a little on the way. If simply changing the xml doesn't do it I would use the reflector to build a new workflow based on the current one. Good luck
#33596
Oct 16, 2009 10:51
