Unable to select TIF-files in ImageURL-property
I have a property of type ImageURL (swe 'URL till Bild') where I can't select an image with extension tif in the "Select Image" dialog.
If I upload a tif-file, then select and press OK I get 'Please select an image first'.
Are there any settings to allow certain file-types? If so, where do I find this?
Thx!
#27036
Jan 15, 2009 9:46
If I look into the source behind the 'Select picture'-page it looks like You should be able to select .tiff files.
In the checkIfImage()-function contains different picture file-extensions and .tiff is one of them but I can't select .tiff either.
I'm using EPiServer CMS 5.2.375.7
#27066
Jan 15, 2009 14:16
No one that knows any solution of this problem?
#27067
Edited, Jan 15, 2009 14:16
Anyone knowing a solution to select a TIF-file in the URL to Image property?
#27592
Feb 03, 2009 17:04
I've used a "URL to document" instead.
#27594
Feb 03, 2009 17:33
I use also Url to document, and convert the tiff to png or jpg
#27598
Feb 03, 2009 23:12
