IPageStore removed
One of R2's breaking changes is that EPiServer.Core.IPageStore has been removed.
A consequence of this is that if your code is using IPageStore.GetPage(...) you will get "method not found" exception.
This is an issue if you're going to upgrade to R2 and is using the Demo Templates for R1. For example the episerver.blog.dll is using  IPageStore and since we didn't ship the source code you better wait untill Demo templates for R2 is released, which is in "very near future".
So to summarize, before doing an upgrade to R2 (which was very smooth and easy with the new installer). Do a test upgrade on a copy of your site and check all functionallity, external modules etc. And read the breaking changes document, and the installtion/upgrade doc.
cheers, Per
#24280
Sep 30, 2008 10:39
... also to clarify...
you can instead use datafactory.instance.getpage() or pagebase.getpage()
#24286
Sep 30, 2008 11:55
Test thread,
EPiServer world now upgraded to EPiServer CMS R2, and if you can read this the forum is also working...
#24336
Oct 01, 2008 9:02
