Xform data post bugs when setting up form as denymultipleposts and requirelogin
I'm experiencing a problem while submitting the xform in CMS 5 , R2 . If I setup the form as
1 .User requires login
2.  Form cannot be posted multiple times .
Whenever I try post the form it rasied error 'You must be logged in to answer' . Whereas I'm already logged in and it does not post any data .
If I turn off the validation , it doesn't raise any error message but also does not save form data .
I believe the second time it should raise the error message 'You have already filled in this form'
I  strip off my custom code and using the 100% episerver default code  - but still getting the error
#26454
Dec 05, 2008 15:38
I have a couple of support cases regarding xforms I need to test first thing monday morning. I'll test your issue as well, and will see if I can reproduce it.
If anyone else have any input during the weekend, you're free to help Wink.
#26459
Dec 05, 2008 19:12
Hello, I am getting the same error when trying to submit a form - I realise this was posted some time ago; but is there a known reason / fix for this? Thanks.
#41638
Jul 19, 2010 10:43
