Ok if no one hase any input how do I go about to make sortable columns for the PageList.
Hi Per,
This is a known bug in sp3 which has been fixed now and I guess will be shiped with R2-SP1.
Bug #15718: DataPager doesn't work with SearchDataSource
Regards
Shahid
EPiServer Support Team
Ok. It's possible to use a pagedatacollection as datasource to the listview, and I have got the paging to work ok with a datapager but I can't seem to get the sorting to work.
I've set the onsorting on the listview and I have linkbuttons with the CommandName and CommandArgument set and the eventhandler is triggerd but nothing happens.
Any tips?
Shahid, can you please confirm that this fix has been shipped with R2-SP1?
Regards,
Anton Kallenberg
I used a asp:ListView control and bound it to a EPi SearchDataSource which worked just fine.
But when I add a DataPager and sets its control id to my listview I get a message like "capacity was less than the current size. Parameter name: value ".
Is I just making some stupid mistake or doesn't it work? I can use a pagelist to get the same looks, but I dont want the paging to be placed on top of the list. Instead I want it to be placed centered below the listing.
Here is the stacktrace.
[ArgumentOutOfRangeException: capacity was less than the current size.
Parameter name: value]
System.Collections.ArrayList.set_Capacity(Int32 value) +7486847
System.Web.UI.WebControls.ListView.CreateChildControls(IEnumerable dataSource, Boolean dataBinding) +509
System.Web.UI.WebControls.ListView.PerformDataBinding(IEnumerable data) +33
System.Web.UI.WebControls.DataBoundControl.OnDataSourceViewSelectCallback(IEnumerable data) +114
System.Web.UI.DataSourceView.Select(DataSourceSelectArguments arguments, DataSourceViewSelectCallback callback) +31
System.Web.UI.WebControls.DataBoundControl.PerformSelect() +142
System.Web.UI.WebControls.ListView.PerformSelect() +57
System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +73
Getinge.Templates.Compass.Pages.CareerSearch.Page_Load(Object sender, EventArgs e) in C:\EPiServer\Sites\GetingeIntra\Templates\Compass\Pages\CareerSearch.aspx.cs:43
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
