Can't find the translation
A small but a bit annoying question.
If you check the language switcher om the demo site (http://demo.episerver.com/), it translate "svenska" with a small "s". I've changed the system setting and also checked every language file but it still comes out formated as "svenska".
Does anyone have a solution to this problem? Am I missing something?
Thanks in advance.
#26564
Dec 11, 2008 14:15
The reason for the behaviour is probably that the 's' in 'svenska' is not capatilized in Swedish. If you select 'svenska' on the demo site you then have the possibility to select 'English', which is the correct way to write it in English. However, I do not know how to change ´svenska' to 'Svenska' if you still desire to do it.
#26722
Dec 17, 2008 12:09
