One more thing
Its running on a IIS7, maybe that is the problem, we dont understand how to configure it in Web.config ?
Very thankful for advice !!
you should try to file a ticket against the component on EPiCode:
https://www.coderesort.com/p/epicode/newticket?component=ImageVirtualPathProvider
This will send an notification mail to the author of the component.
You could also check out the code directly and look for things that are OS sensitive (like interop).
/Steve
We have a little problem. We are using a component for generating images from text. The name of this component is:
Cognifide.ImageVirtualPathProvider
Everything is working fine on Windows XP and Windows Server 2003 R2 (both 32 bits)
When we trying to use this on EpiServer Hosting and theire 64 bits system, it does not seem to work.
Is there anyone knowing anything about this component, if it is not made for 64 bits system ?
In that case : Does someone know if there are another, simular component out there, that works in a 64 bits environment ?
One more problem is that our company does not have a 64 bits environment to test/debug this on?
Very thankful for advices !!
