Upgrading to R2
I'm trying my best to do an uppgrade from an EPiServer CMS 5 SP3 to R2. The Installation Manager gives me an error messege.
"Error - Source and destination path must have identical roots. Move will not work across volumes."
My site is on my F: -drive and the manager is on the C: drive.
Any suggestions
/Marcus
#24578
Oct 01, 2008 13:29
Moving it to my own computer and trying the same gives an other error:
"Error - Access to the path 'entries' is denied."
#24581
Oct 01, 2008 14:37
Hey,
We have the same issue this morning with this website. I reported it as a bug on the installation manager this #14916. You cannot (currently) have your website installed in a different volume than where the installation manager is.
#24582
Oct 01, 2008 14:42
The solution is to move your site to c:. You cannot choose were to install the manager, it will go into the <program files> volume.
/Per
#24583
Oct 01, 2008 14:44
When a site is upgraded to R2 the EPiServer UI directories are removed from the site folder and added via virtual path provider configuration in web.config.
The upgrade is done in a transactional manner so the directories are moved to the Windows temp folder in the first phase of the upgrade, and deleted in the commit phase.
Unfortunately the move step fails when the temp folder resides on a different drive than the site.
To work-around the problem you can move these folders manually to a temporary location before completing the upgrade wizard.
The affected folders are listed on the 2nd page of the upgrade wizard.
#24586
Oct 01, 2008 15:02
And it seems like I have to remove my subversion integration in the project. "entries"  is an subversion file inside the project folders.
#24587
Oct 01, 2008 15:08
Another change that I see is that my own urlRewrite provider isn't necessary anymore.
FriendlyUrlRewriteProviderNoRebase doesn't compile anymore but the ordinary EPiServerFriendlyUrlRewriteProvider does the trick the right way now.
http://labs.episerver.com/en/Blogs/Johano/Dates/2008/7/Friendly-URL-with-no-rebasing/
#24597
Oct 01, 2008 15:52
