Is the source available for the EPiServer.blog dll?
I am trying t debug why my blog is not working, and I would make it a lot easier if I coild take a look at the EPiServer.blog code.  Is this available somewhere?
Brian
#25555
Oct 29, 2008 19:56
You can use this tool to explore the episerver blog dll:
http://www.red-gate.com/products/reflector/
Almost the same as having the source code :), I use it alot myself.
#25557
Oct 29, 2008 21:55
The episerver.blog.dll that was released before EPiServer CMS R2 will not work, so you'll need to get the demotemplates that are released for R2.
Also, the dev team has recently setup a symbol server so you can debug against EPiServer CMS. I'm not sure if demotemplates are up yet. However, the address is symbols.episerver.com and you can read more about it in this article:
http://world.episerver.com/en/Articles/Items/Debugging-EPiServer-CMS-5-R2/
Otherwise you could post your problem here and maybe we can help you or contact me and I'll send you the blog code.
Regards Per
#25558
Oct 29, 2008 22:28
