Creating a custom protected module
I would like to create a module for EPiServer and don't know where to begin. I've read some articles here and there, but some seem a little outdated.
What I'm looking to do, is to make a module that i stored in ~/modules/_protected/ - in a zip-file and its assembly is referenced in my project(s), so I can access the code from there.
Think of it as my own little re-usable code. But also as a way to standardize extensions to the CMS UI.
How do I begin?
/Kristian
#150236
Jun 14, 2016 15:24
What kind of extensions are you talking about? If it's only code extensions then standard nuget package is more suitable than a protected addon.
Addons should not have references from your code. They should be stand alone. Use standard nuget package instead if you need that part.
#150240
Jun 14, 2016 16:34
By extensions I mean for example an admin part to manage some settings, or a UI panel in edit mode to, or a gadget.
But from what I can hear, I should separate the projects: a NuGet package for the code I want to access, and a zip-file / module to enrich Episerver.
Speaking of the latter; module. How do "they" make them? From what I can see it's just a zip-file with at least a module.config file, and then it's referenced (somehow?) in the web.config:
<episerver.shell>
<publicModules rootPath="~/modules/" autoDiscovery="Modules" />
<protectedModules rootPath="~/EPiServer/">
  <add name="Shell" />
  <add name="CMS" />
  <add name="EPiServer.Packaging.UI" />
</protectedModules>
</episerver.shell>
So that's what I want to know more about.
/Kristian
#150255
Jun 15, 2016 8:35
I did a few of those. It takes a little while to get the first up and running but it's not really hard. You can start by reading the documentation about addons here
http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/add-ons/Developing-Add-ons/
The important parts is for protected addons in your case. Hope that helps to get you started. An addon is a nuget package that is easy to install/delete more or less with a few bells and whistles to solve some routing of resources (images/css/js) and similar.
#150262
Edited, Jun 15, 2016 9:03
