UnifiedSearchQuery only returns 100 results maximum
I have a UnifiedDirectory with 4500+ files in it. When I perform a search using a UnifiedSearchQuery, the UnifiedSearchHitCollection capacity gets reset to 128 and the count returns 100 during the query - for pretty much every query. There's no way the search returns exactly 100 results for most of the criteria. How do I override this behaviour and get all ranked files? There is zero help in the SDK.
		UnifiedSearchHitCollection searchresult = new UnifiedSearchHitCollection();
		searchresult.Capacity = 999;
                query.FreeTextQuery = txtSearchValue;
                searchresult = dir.Search(query);
Thanks in advance.
#122431
Jun 02, 2015 15:13
It looks like the page size == 100, is used as a constant and there is no elegant way to change it.
Maybe you could try to use a trick (I didn't test it):
// change the implementation of SearchHandler
        public class ExtendedSearchHandler: SearchHandler
            public override SearchResults GetSearchResults(IQueryExpression queryExpression, string namedIndexingService, Collection<string> namedIndexes,
                                                           int page, int pageSize)
                pageSize = 10000;
                return base.GetSearchResults(queryExpression, namedIndexingService, namedIndexes, page, pageSize);
// use your code below
// replace the instance of searchHandler
SearchHandler.Instance = new ExtendedSearchHandler();
#122451
Jun 02, 2015 22:25
Hi, thanks Grzegorz. I will give this a shot.
#122473
Jun 03, 2015 11:06
Grzegorz, you are a total legend. Worked first time! Thanks again! :D
#122489
Jun 03, 2015 12:33
