EPiServer 7 to 7.5 Migration
Once I migrate EPiServer code from 7 to 7.5 I am getting the below errors:
  • 'EpiServer.Web.PageExtensions.ContextMenu' does not contain a definition for ‘Current’
  • 'EpiServer.Web.PageExtensions.ContextMenu' does not contain a definition for ‘Menu’ and no extension method ‘Menu’ accepting a  first argument of type 'EpiServer.Web.PageExtensions.ContextMenu' could be found(are you missing a using directive or an assembly reference?)
  • 'EpiServer.Web.PageExtensions.ContextMenu' does not contain a definition for ‘CurrentPage and no extension method ‘CurrentPage’ accepting a  first argument of type 'EpiServer.Web.UI.Control’ could be found(are you missing a using directive or an assembly reference?)
  • The name 'EditorToolOptions' does not exist in the current context.
Any idea as to how we can fix these?
#122419
Jun 02, 2015 13:41
The context menu is no more in cms 7.5
http://talk.alfnilsson.se/2014/01/29/hooking-up-to-the-episerver-quicknavigator/
You could also have a look in the class lib and see that it is replace by the quicknavigator:
http://world.episerver.com/documentation/Class-library/?documentId=cms/8/DAD56B6C
And therefore marked as obsolete:
[ObsoleteAttribute("ContextMenu has been replaced with EPiServer.Web.PageExtensions.QuickNavigator.",
	false)]
public class ContextMenu
#122434
Jun 02, 2015 15:30
So I cant se a fix but you need to rewrite the code and might need to delete som stuff as well since you do not have the same options.
#122435
Jun 02, 2015 15:32
