Using a GlobalSetting on all TinyMCE editors
Hey Guys,
using episerver 8 i have the following question.  I want all my xhtmlstring property (tinyMce) to have a specific set of buttons etc.  (different from the default once came with episerver).
Now i have created a global settings in the CMS via admin .
Is there a way to decorate all my xhtmlstring properties to let it know to use the newly created globalsetting?
Or how would you do this?
#120449
Apr 17, 2015 12:00
Hi, Vishal,
You can easily set the setting as default in admin mode. However, you would need to do the same once you deploy this to a different environment (ex. staging or production server).
In newer versions of EPiServer, there is a way is to define the settings from code, see an example here (not IsDefault = true in constructor).
See this screenshot:
The red is the first non-code way (you need to click Save, it happens sometimes that I forget this, sorry if it obvious :)). The pink underline is what is coming from code (Linus's post I linked to earlier).
#120451
Edited, Apr 17, 2015 12:28
Awesome Marija.. the link to Linus's post is what i needed.
I can do it manually, but i'm sure to forget it on all the staging and Production environments.. :-)
#120454
Edited, Apr 17, 2015 12:51
If you're developing for EPiServer 8, I would recommend defining the settings from code instead:
[ServiceConfiguration(ServiceType = typeof(PropertySettings))]
public class DefaultTinyMCESettings : PropertySettings<TinyMCESettings>
    public DefaultTinyMCESettings()
        this.IsDefault = true; // Makes this setting default!
        this.DisplayName = "A display name";
    public override TinyMCESettings GetPropertySettings()
        return new TinyMCESettings
            ContentCss = "/css/editor.css",
            Width = 580,
            Height = 300,
            ToolbarRows = new List<ToolbarRow>
                new ToolbarRow(new[]
                    TinyMCEButtons.Bold,
                    TinyMCEButtons.Italic,
                    TinyMCEButtons.Separator,
                    TinyMCEButtons.NumericList,
                    TinyMCEButtons.BulletedList,
                    TinyMCEButtons.Outdent,
                    TinyMCEButtons.Indent,
                    TinyMCEButtons.SuperScript,
                    TinyMCEButtons.SubScript,
                    TinyMCEButtons.EPiServerQuote,
                    TinyMCEButtons.CharacterMap,
                    TinyMCEButtons.EPiServerLink,
                    TinyMCEButtons.Unlink,
                    TinyMCEButtons.Anchor,
                    TinyMCEButtons.Image,
                    TinyMCEButtons.EPiServerImageEditor,
                    TinyMCEButtons.PasteText,
                    TinyMCEButtons.CleanUp,
                    TinyMCEButtons.RemoveFormat,
                    TinyMCEButtons.Code,
                    TinyMCEButtons.Fullscreen
                    TinyMCEButtons.FormatSelect,
                    TinyMCEButtons.StyleSelect,
                    TinyMCEButtons.TableButtons.Table,
                    TinyMCEButtons.TableButtons.RowProperties,
                    TinyMCEButtons.TableButtons.CellProperties,
                    TinyMCEButtons.TableButtons.InsertRowBefore,
                    TinyMCEButtons.TableButtons.InsertRowAfter,
                    TinyMCEButtons.TableButtons.DeleteRow,
                    TinyMCEButtons.TableButtons.InsertColumnBefore,
                    TinyMCEButtons.TableButtons.InsertColumnsAfter,
                    TinyMCEButtons.TableButtons.DeleteColumns,
                    TinyMCEButtons.TableButtons.SplitCells,
                    TinyMCEButtons.TableButtons.MergeCells,
                    TinyMCEButtons.Undo,
                    TinyMCEButtons.Redo,
    public override Guid ID
        get { return new Guid("9d776ac1-4dc7-4789-ac9c-124f34b8c275"); }
You can also decorate properties with other settings:
[PropertySettings(typeof(AnotherTinyMCESettings))]
[Display(GroupName = GroupNames.Tabs.TeaserInformation, Order = 1)]
public virtual XhtmlString TeaserBody { get; set; }
#120483
Apr 17, 2015 18:57
Sorry Marija, missed your third paragraph where you mentioned settings from code...
#120484
Apr 17, 2015 18:59
No worries :)
#120486
Apr 17, 2015 19:46
