Display list of most recently changed pages
Is there a way to display a list of links to the most recently updated pages (up to 10) on Epi 7.0?
#121015
Apr 29, 2015 20:17
There's a built-in gadget for that (see this topic). If you'd rather do it through code, I believe you should check ChangeLog.GetChanges.
#121028
Edited, Apr 30, 2015 0:43
Thanks for a quick reply Johan. I am very new to this so I think I need more direction. Also I'll clarify - I want to display the list of pages (linked) on the user facing website. So when a user goes to our home page, it shows a list of links to the most recently changed pages. Can you elaborate on how I would go about that?
#121072
Apr 30, 2015 14:48
If you are using ASP.NET MVC you could try something like this. I wrote the code here so it's not tested but I think it should work just fine.
public ActionResult Index(PageData currentPage) {
  var queryService =  ServiceLocator.Current.GetInstance<IPageCriteriaQueryService>();
  var changedPages = GetRecentlyChangedPages(queryService, 10);
  // do something with the result
public IEnumerable<PageData> GetRecentlyChangedPages(IPageCriteriaQueryService queryService, int daysBack) {
  var criteriaCollection = new PropertyCriteriaCollection();
  var criteria = new PropertyCriteria {
    Condition = CompareCondition.GreaterThan,
    Name = "PageChanged",
    Type = PropertyDataType.Date,
    Value = DateTime.Now.AddDays(-daysBack).ToString(),
    Required = true
  criteriaCollection.Add(criteria);
  return queryService.FindPagesWithCriteria(ContentReference.StartPage, criteriaCollection);
Cheers
- Marcus
#121079
Edited, Apr 30, 2015 16:22
