Unable to find a module by assembly 'EPiServer.Labs.LanguageManager
Hi everybody this is might be a stupid question but what is EPiServer.Labs.LanguageManager?
I got an error below when run application
Unable to find a module by assembly 'EPiServer.Labs.LanguageManager, Version=1.0.2.71, Culture=neutral, PublicKeyToken=null'
Parameter name: moduleAssembly
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: Unable to find a module by assembly 'EPiServer.Labs.LanguageManager, Version=1.0.2.71, Culture=neutral, PublicKeyToken=null'
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\151a0da9\bf6d0241\App_global.asax.zlutdxzo.0.cs    Line: 0
How to fix it?
#90411
Sep 09, 2014 12:05
That is the episerver languages add on. I'm guessing you are missing it from your modules folder.
#90415
Sep 09, 2014 12:31
Hi Per, I cannot log in cms right now and cannot run application so where can i download episerver languages add on and config it to work with application?
#90420
Sep 09, 2014 12:58
Try removing EPiServer.Labs.LanguageManager.dll from your modulesbin directory in order to get back into the cms
#90426
Sep 09, 2014 13:53
Late answer, but for reference sake:
Your path to the AppData folder is probably wrong. Check the file EPiServerFramework.config
#146931
Mar 31, 2016 10:34
