Page selection popup error
We have created custome property types using base as Page type property in Episerver5, now we have migrated application to Episerver CMS 7
 When we try to access page structure in Edit mode it gives following error message, Can you please help us?
 Siden kunne ikke lastes inn
Koblingen som du angav, virker ikke. Dette kan skyldes manglende vedlikehold eller at det er en feil med koblingen.
Detailed error information (authorized by permissions to functions)
Error occured 22.09.2014 08:36:36
User Agent Mozilla/5.0 (Windows NT 6.1; WOW64; rv:32.0) Gecko/20100101 Firefox/32.0
Url https://testserver:443/EPiServer/CMS/edit/pagebrowser.aspx?id=6426&disablecurrentpageoption=False&info=FullRegion_ArticleLink3_ctl00_Display&value=FullRegion_ArticleLink3_ctl00_Value&epslanguage=no&displaywarning=False&requireurlforselectedpage=false
Referer https://testserver/EPiServer/CMS/Home
PageReference: Input string was not in a correct format.
Exception Details: EPiServer.Core.EPiServerException: PageReference: Input string was not in a correct format.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of
#90904
Sep 22, 2014 10:01
