CustomProperty is NULL after upgrading
I'm having some issues with a custom page property which worked fine in v6, but not in v7. It seems like the values previously populated in the property is gone. On page load my custom property (CurrentPage.Tags) is always NULL. However, if a add a new value to the property, the property is no longer NULL - but only showing the new value(s), not values stored pre-v7.
Here's the basic layout of the custom property:
From the PageType class:
        [BackingType(typeof(PropertyTags))]
        [Display(Name = "Tags",
            Description = "",
            Order = 3100,
            GroupName = Helper.ContentTypeGroupNames.InformationTab)]
        public virtual CategoryList Tags { get; set; }
The custom property class:
 [Serializable]
    [PropertyDefinitionTypePlugIn(DisplayName = "Tags", Description = "Tag selector")]
    public class PropertyTags : PropertyCategory
        public override IPropertyControl CreatePropertyControl()
            return new TagsControl();
The TagsControl class:
public class TagsControl : PropertyStringControl
        public override void CreateEditControls()
         // add ui-interface for add/removal of strings
        protected override void OnPreRender(EventArgs e)
            // populate ui-interface
        public override void ApplyEditChanges()
           // save changes
Any ideas to why this is happening?
#89886
Aug 28, 2014 9:17
This is the original custom property (haven't changed much)
Edit:
I found a work-around which gets the job done, for now:
var tagsCategory = EPiServer.DataAbstraction.Category.Find("Tags");
var categoriesForCurrentPage = CurrentPage.Category;
var tagsForCurrentPage = new CategoryList();
foreach (int catId in categoriesForCurrentPage)
if (tagsCategory.FindChild(catId) != null) tagsForCurrentPage.Add(catId);
#89889
Edited, Aug 28, 2014 10:02
Now I've made a temporary work-around by doing the following
Which works fine for now.
[Pasting files is not allowed]
#89894
Edited, Aug 28, 2014 11:22
Having some trouble editing posts here...
I made a work-around which gets the job done:
#89895
Aug 28, 2014 11:36
That is the old way of doing custom properties.
Joel describe nearly the exact same custom prop here and how he solved it to be able to use it in a legacymode
http://joelabrahamsson.com/upgrading-a-site-from-episerver-cms-6-to-episerver-7/
#89950
Aug 29, 2014 7:15
Thank you Henrik, that did the trick!
#89955
Aug 29, 2014 8:09
Great to know OerjanH!
#89958
Aug 29, 2014 8:31
I seems I still have some strange behavior going on. The custom property will work fine as long as I've edited the property and published the page. However, initially, before editing the custom property, the property will be NULL when accessed in the template. Eventually, I will probably either migrate to another tag plug-in or at least convert the legacy property to Dojo.
The following gets the job done until then
            if (CurrentPage.Tags != null && CurrentPage.Tags.Count > 0)
                DoSomethingWithTheData(CurrentPage.Tags.ToArray());
            else
                DoSomethingWithTheData(tagsForCurrentPage.ToArray());
#90463
Sep 10, 2014 10:53
Just an update:
After upgrading from 7.0 to 7.5 (7.13.3) I am no longer having this issue.
#90871
Sep 19, 2014 14:51
