Unfortunately, the current Publish From Office add-on only supports mapping two fields from your Word document; "title" (typically your heading) and "description" (everything else in your document). This is due to limitations in the MetaWeblogAPI used by the add-on.
When you go to "Share > Post to blog" in Word, your document will be shown in "blog post" layout, with placeholder frames for the "title" and "description" fields.
Any formatting/styles (e.g heading1, quote, strong etc) you have used in your document should be preserved when published to EPiServer.
Read more in the Publish From Office webhelp section.
When configuring the Content Channel for the Publish from Office feature, how do you map the Word content into the PageType properties.
For example, in the Word document, is it possible to map on "overview" paragraph into the Overview field of a PageType. Or, to map the "content" paragraphs into the "MainBody" field of an EPiServer PageType?
If the entire content of the Word document has to go in to a single field, how do you specify the field that content should go in to?
