Validation of viewstate MAC failed
I'm getting "Validation of viewstate MAC failed" in an IFrameComponent. I've tried disabling EnableViewstateMac, EnableEventValidation, ViewStateEncryptionMode... both on the page, web.config and on the controls. Nothing seems to help. I read that machinekey also could be an issue but it doesn't seem like it in my case.
The error occurs when I click a button that posts to the server. When debugging all values are correct and no exceptions are thrown.
In another IFrameComponent that has an input field and a button the error occurs if I type in the input field and hit enter. If I type and the click the button with the mouse everything works as expected.
I worked around that problem by wrapping the input and button in a panel with the defaultbutton set. Sadly that doesn't work for my new component.
Has anyone else had this problem?
/Peter
#86263
May 16, 2014 13:56
It was the action attribute on the <form> tag that somehow messed things up. I removed it after the page has loaded and then everything works.
/Peter
#86956
Jun 05, 2014 10:43
