Visitor groups Landing URL criteria
I’ve come across an issue in CMS 7. If I go to
CMS -> Visitor Groups -> Create -> Drag a LandingUrl criteria from within URL Critera and drop it onto the Critera panel
I get the following error:
An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
CS1061: 'System.Web.Mvc.HtmlHelper<EPiServer.Personalization.VisitorGroups.Criteria.StartUrlModel>' does not contain a definition for 'Translate' and no extension method 'Translate' accepting a first argument of type 'System.Web.Mvc.HtmlHelper<EPiServer.Personalization.VisitorGroups.Criteria.StartUrlModel>' could be found (are you missing a using directive or an assembly reference?)
Line 8:      </span>
Line 9:      <span class="epi-criteria-inlineblock">
Line 10:         <%= Html.DojoEditorFor(p => p.Url, new { @class = "episize300" }, Html.Translate("/shell/cms/visitorgroups/criteria/starturl/url"), "epi-criteria-label")%>
Line 11:     </span>
Line 12: </div>
/EPiServer/CMS/Views/Shared/EditorTemplates/StartUrlModel.ascx
The LandingURL criteria is built in functionality so is this a bug? Has anyone found a fix or workaround for this? This implication is that I have a missing assembly containing the definition of Html.Translate() but I can replicate the issue on two separate developer machines, a test and, a production environment so that seems doubtful.
#85836
May 06, 2014 17:33
